This is a text-only command.
Type the text equivalent at the command prompt to add a Network
Use the network command to create a new wall, road or river.
To draw a new network:
The prompt reads "1st corner:". Select the first point using the crosshairs, or type numeric coordinates.
CC3 displays a rubber-band cursor anchored at the first point.
The prompt reads "Next point:". Select a node point on the network to create a span.
CC3 draws one span, using the current network width. Note how the end of the wall is automatically capped. If you continue adding wall segments, the intersections are automatically cleaned up, even if you eventually return to the first point.
The prompt reads "Next point:". If desired, continue to select nodes. After placing the last point of the path, right-click to and choose Done from the Networks popup menu.
Notice that anytime during the wall drawing process, a right-click will display the Netwiorks popup menu. This control lets you quickly select the next action to take.
Text equivalent: NET
Related topics
