Stretch
  1. Select the entities to stretch. Usually, you will enclose the points to be moved in a selection rectangle (window)
image\button.gif%HowTo_SelectEntities>howtomap How?%HowTo_SelectEntities>howtomap
  1. The prompt reads "Stretch window:". Click points to form a selection rectangle around the nodes you want to move.
  2. The prompt reads "Move from:". Click a start point for the move.
CC3 displays a rubber-band cursor anchored at the move from point.
  1. The prompt reads "to:". Select a point to indicate the distance and direction you want the points in the window to move.
CC3 moves the endpoints that were inside the stretch window, leaving other endpoints where they were.
Text Equivalent: STR
