Right click Text to access Lock Text Angle.
LOCK TEXT ANGLE changes the text angle to align along a selected straight edge. It resets the default text angle for all text placed in the future until you change the text angle again..
To lock the text angle select Text > Lock Text Angle:
The prompt reads "Select straight edge:". Use the pick box to select a wall to which you want to lock the text angle.
Place some text. It will be at the same angle as the straight edge.
Lock Text Angle Tips
· If you use Lock Text Angle and find that the text is 180 degrees out, lock text angle again, selecting the opposite end of the straight edge.
· To lock along a curve, draw a Perpendicular Line from the point on the curve, then select Lock Text angle on this line.
Text Equivalent: LOCKTEXT
