Right click Change Properties to access Change Text Properties.
CHANGE-TEXT PROPERTIES redraws selected text with user-modified properties. Text properties include Font, Metrics, and Character style.
Select text entities to modify using the Entity Selection dialog box.
CC3 automatically displays the Text Properties dialog box. The current text specifications are displayed. Clicking on and/or changing any value (or font name) will result in the selected entities acquiring the new property values.
· If you want to change the text properties to match the current settings, choose the Change everything radio button.
· If you just want to change a few properties (say just the height), choose the Change only touched items only properties you adjust will affect the selected text.
This action does not change the current text specifications, only the existing selected entities.
Choose the OK button to accept the changes and close the dialog box. The text entity will redraw with the modified properties.
To change the text string:
Use the Edit command (Edit > Edit).
Text equivalent: CHANGET
Related topics
