Roof colors are controlled from the House Settings dialog box.
1 Choose a dark color.
2 If you are using a three-color scheme, choose a middle color, which should be one or two shades lighter.
3 Choose a light color. This should be one or two shades lighter than the middle color.
4 Choose a color for flat roofs. This color only appears if you select a Flat Roof house type when inserting.
5 If you deselect the Use 3 color scheme, CD2 will only use the Dark and Light colors when you add houses/
6 Choose an outline color. This is usually black, but doesn’t have to be.
7 Choose a color for your roof hatching.
