Click Edit Properties to change the properties of a single entity.
EDIT PROPERTIES allows you to edit the standard properties of a single selected entity through an interactive dialog box. The properties you can edit are similar to those you would edit using the various CHANGE commands:
· Layer
· Line Style
· Fill Style
· Line Width
· Color
· Text Style (when a text entity is selected)
CC3 displays a pick cursor. Select any single entity. The entity can be discretely selected if part of a group. Multipolys select as a single entity (any changes affect the entire multipoly). Symbol references cannot be selected. If you pick on a stack of entities, the lowest will be selected.
Note: If a selected entity is part of a group, you cannot use UNDO to restore the previous properties.
CC3 displays the Entity Properties dialog box. Modify the desired property and choose the OK button.
Text equivalent: PEDIT
Related topics
