Non-Visual Mirror
Right-click Move, Scale Rotate image\MOVE.gif, to access Mirror.
MIRROR transforms an entity into a mirror image of itself, flipped over a mirror line that you specify.
  1. Select entities to connect using the Entity Selection dialog box.
  2. The prompt reads "Mirror line start:". Select the mirror line’s starting point.
  3. The prompt reads "Mirror line end:". Select the mirror line’s ending point. The mirror line can be drawn at any angle.
CC3 flips the entities and terminates the command.
Text equivalent: MIRROR
Related Topics
