Arcs: Start, Middle and End
START, MIDDLE AND END draws an arc from a starting point, a point on the arc, and an ending point.
  1. The prompt reads "1st Point:". Specify the 1st point by using the cursor or by typing numeric coordinates.
  2. Select the 2nd and 3rd points in a similar manner. You can enter the points either clockwise or counterclockwise. A stretching arc cursor is displayed after you place the second point.
CC3 draws the final arc from the first point, through the second, and to the third point.
Please note: If you select three points in a straight line, an arc would be mathematically impossible, so CC3 displays a message box: "Can't create entity because: Three points are in a straight line." Choose the OK button or press ENTER to clear the message.
Text equivalent: ARC3
