Show
Move, Scale, Rotate
Click Move, Scale, Rotate image\MOVE.gif to dynamically reposition, resize and change the angle of selected entities.
  1. Select the entities you wish to reshape
  2. image\button.gif How?
The prompt reads "Place (Shift = 15° Rot, Shift+Ctrl=Rot, Ctrl=Scale):".
  1. As you move the mouse, the entities move to follow. Click to place the entities in their new position. If you don’t wanr to move, only scale or rotate, end the command with a right click.
  2. Press CTRL and move the mouse to scale the selection, making them larger or smaller depending upon direction of the mouse movement. Type in a number at the command prompt and CC3 will scale the entities by that amount.
  3. Press SHIFT to rotate the selection with a snap to the nearest 15°. Press CTRL+SHIFT to rotate the selection about the "Move from" point.
Note
Text equivalent: MOV
Macro Equivalent: MOVE – move only
